PW6 - scaler
Discussion in 'Plasma TVs Forum' started by alex_30252, Oct 23, 2004.
  1. alex_30252
    alex_30252
    After going through your comments, finally decided to go for a PW6.
    Still using standard video resolutions on my DVD player (YUV) and sat receiver (scart RGB).
    Should I spend another $1000 for a scaler ?
    What would be the best fit with the PW6?
    Alex
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    PWD6 or PHD6 ??????????????? IF a PHD 6 then i reconmend the Iscan HD via DVi
    PW6 no so critical...... but an iscan HD at 720p will get the very best out of a panel....
  3. alex_30252
    alex_30252
    In Switzerland, the ref is TH-42PHW6EX (1024x768) or TH-42PW6EXS (8524X480).
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    You need a demo to see if you think it's worthwhile. There is a noticeable improvement, particularly with poor sources, and of course it will take care of your lip sync too. Find a local dealer and see it perform.
  5. alex_30252
    alex_30252
    Hard to find a demo for a scaler in Switzerland.
    Looks like you guys in the UK are at least 2 years ahead.....
