pw6....pw7...or pw8... which to keep??
Discussion in 'Plasma TVs Forum' started by RonBurgundy, Mar 20, 2006.
  1. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    ok so bit of a strange question, but due to upgrades and impulse buying i now have:
    • [*]42 inch pw6 done 160 hrs
      [*]37 inch pw7 done 150 hrs[*]42 inch pw8 done 141 hrs
    question is.... which do i keep??
    ideally i want a black display... which only the pw6 has, however i would be willing to get the 8 sprayed as its a gloss black like the pioneers im after more than the charcoal...think this costs about £50 from bf interactive near me!
    and no its not an option to get rid of all 3 for a 50 inch or a PHD or pioneer etc as at the moment i dont want that much money tied up in a plasma
    i estimate the values at around:
    pw6- 750
    pw7- 700
    pw8- 900/950
    so my question is... is it worthwhile keeping the pw8 at the extra cost or should i just stick with a solid pw6 and bank a few hundred quid?
    or as i have got a new projector now should i just get rid of the 42s and keep the 37 and bank a little more?
    any comments / suggestions welcome!
    oh and theres only space for one screen in the bedroom!
  2. HoTTdog
    HoTTdog
    Feb 7, 2006
    190
    Kent
    I reckon your estimate for the PW8 is a little optimistic as a new one is 1080. Personally speaking I'd have the PW8 as you're maybe talking about £200 notes between PW6 and PW8. And if you want a bespoke shiny black finish then the PW8 is the one to keep; spraying it might adversely impact future resale value though... :confused:
  3. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    or then again it may be worth more to someone else who would like a gloss black one to go with their decor? woiuld have to wait and see on that one i guess. pw8 is unregistered for warranty and with minimal hours and a board so i think it could be ok,
  4. HoTTdog
    HoTTdog
    Feb 7, 2006
    190
    Kent
    Aye, you might be right :)
  5. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    Which do u think is better in regards to PQ?
    I found the PW6 alot better then the PW7 using the VGA input and a decent source
  6. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,525
    Kent
    +830
    Have a look, see which one has the better pic, and keep it!
    If you can't tell a difference, keep the 8-series because the HDMI option will actually work even if it won't be displaying HD with full resolution.
  7. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    Get a good progressive source and test them using the same inputs. The vga input on the pw6 is fantastic
  8. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    at the moment i have just hooked up the playstation via composite on both, because it was easy!
    however i may lie them down on the floor next to eachother and run the pc through vga and see what i think, or even swap the component board into the 8 and see how that looks from my pio 575
    immediate thoughts were that the 8 looks a bit more vibrant with the colours but then that could just be the menu settings which i have not yet tweeked
    liam, with regards to the hdmi does this mean that its hd comp and will just scale down the hd to make it more 'defined' than normal tv but not quite hd?
    no tecchy answers please as i wont understand them!
    keep the comments coming guys!
  9. UKseless1
    UKseless1
    Mar 9, 2005
    842
    28
    +36
    Yep - I think that's exactly what he means.
  10. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,222
    83
    Over the Hill & Far Away
    +140
    Not sure I would recommend lying the plasmas on the floor!
  11. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    would have thought it would be ok for five or ten mins so i can compare them directly?
    no stands!!
  12. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,525
    Kent
    +830
    Save yourself monkeying around and keep the 8.
    And that's exactly what I mean r.e. HD. The screen will accept the signal and downscale (which gives a sublime image anyway!) whereas the 6 and 7 won't even accept the image digitally.
  13. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    ok thanks liam
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    i think your estimates are bit high, PWD6 isnt worth £750 IMO not as a bare panel, but i suggest you keep the 8 sell the other 2 and try to calm down (ideal time to flog em stick the cash in an ISA till this time next year then sell the PWD8 and get a 50"
  15. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    lol @ calm down, i have acquired these over a few months... the 6 was an upgrade to the 7(well size wise) and i just have not really got round to selling it, and the 8 was more the impulse buy this week!
    well im an accountant now and were meant to be boring not impulsive.. and i have got my ISA all sorted but definitley good advice!
    with a bnc / rgb card or both i think it will go on here for a decent price- as its almost new and the last couple in the classifieds got alot of interest
    everyone seems to be swinging towards the 8- i guess because its more future proof.
    a 50 would be nice but like i said dont really want that much tied up in a screen as im only 20 and will soon need cash to go towards a deposit on a house.
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    i think keeping the 8 is the best bet, but even selling all 3 wont put much a of dent in a deposit, it may not even cover the costs of buying so dont bank on it too much
  17. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    again very true, but it will definitely be where im putting the money, house is going to be a buy to let thing with a friend of mine who is considerably more well off (ie. loaded) who is giving me the opportunity to get onto the market with him, on the condition that i do the leg work as he is busy running his company
    so that plus a bit of savings and pay going up steadily at work while im becoming more qualified should be ok!
    anyway back on the subject.... the 8 sounds so far like the way to go .. may stick the 6 on the forums tonight and see what happens!
    theres always someone on here willing to buy this sort of thing so hopefully il be fine and a few hundred quid better off by the end of the month!
    im going to do a thread on how i have done my HC on a budget and how it turns out so hopefully might give a few others a bit of inspiration when doing theres!
  18. p203557
    p203557
    Aug 27, 2005
    990
    St Albans
    +27
    If you do put this up on the classifieds and someone is looking for a cheap stand. Please point them in the direction of my pedestal stand on the classifieds now.
    Richard
  19. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    lol... will do:smashin:
  20. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,752
    The Borders
    +3,520
    smiders29
    If your feeling Impulsive I knwo a man with a couple of VGA 'loop' though boards going for a good price so you can view your PC on all three simultaneously :)
    £50.00 is mighty cheap for spraying a Panasonic bezel - stripping the bezel from the display and then stripping the front filter from the bezel is a nightmare.
    Best regards
    Joe
  21. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Smiders mate can you ask them if they do Sky+ boxes?
  22. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    horny they are at www.bfinteractive.tv
    they are in shrewsbury and when i went in the shop a while ago i seem to remember £50 being the figure he quoted so i hope it is still... i emailed them earlier today about my screen so im awaiting a reply
  23. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    I may give a ring its just being without the box for a week to get it done will kill me! (welll missus will!)
  24. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    I just checked my email and they said that they can only spray the panel if they supplied it!
    :mad: :mad: :mad:
    which is completely against what the guy in the shop told me when i was in there... as we were talking about the forums infact!!!
    anyone know of anywhere else offers the service?
  25. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    teressaTT or perhaps Lisag had silver one sprayed black by a place in oxfordshire that are accredited to do it by panny
  26. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    thanks il try a pm
  27. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    And picture wise. By the way, don't they teach accountants to use shift keys these days? ;)
  28. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,661
    41
    +21
    they erm.... teach us to be as time / cost efficient as possible...think of all the time holding shift takes up!! :rolleyes:
