PW6/PW7 Connection question
Discussion in 'Plasma TVs Forum' started by 3ill, Sep 28, 2004.
  1. 3ill
    3ill
    Sep 26, 2004
    28
    Hi Guys, first off, as you can tell I'm new to this forum and to the whole world of AV goodness and this forum is a great resource for people like me.
    Anyways, like most of you I've caught the itch to buy a plasma/av receiver/speaker package I’ve got my list down to the following items
    Panasonic PW6/PW7
    Sony STR-DB795
    Toshiba SD-340E
    Morduant-Short Genie
    Into the AV, I'll be connecting my SKY+ and xbox.
    I want to go for a clean install, concealing all wires where possible, so I thought that I would buy the component socket module for the plasma TV so I would have just one cable running from the AV to the plasma.
    BUT, the more I read about ppl who have this plasma, they have chosen the JS RGB to VGA converter box to connect the SKY+. Is there a particular reason for this? Will the way I want to configure it (with just the one component cable running from the AV to the Plasma) not give as good a picture?
    Should I be looking at different plasma’s in order to accomplish what I am after?
    Thoughts/Comments are greatly appreciated by this n00b!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    to do what you want to do i suggest you look at an AV reciever that has video upscaling built in, this will allow you to run 1 cable (reconmend you run a couple of others for future uses as well HDMI and VGA +S-video)
    Also reconmend you consider http://www.progressive-av.com/flat_screens/fujitsu_p42vha30.htm as an alternative to the panny.
    and cosider the denon 2805 reciever which has video upconnversion allowing S-video (sky+) to be fed into amp and output as component to the screen: http://www.creative-audio.co.uk/HCS_DEN2805_KHT2005.htm
