PW6 - PA20 and Scart Cables
Discussion in 'Plasma TVs Forum' started by novaya_zemla, Oct 27, 2004.
  1. novaya_zemla
    novaya_zemla
    My PW6 sits on a PA20 stand and I have very little room for a scart cable connection - my old plastic £1.99 lead just fits... I have had to return a Thor cable because the lead comes straight out of the back of the socket and does not 'angle' out. It seems that all the more upmarket cables have quite a large casings around the connectors and this is giving me a few problems.
    I have been looking on the tvcables website and was wondering if anyone has tried a ribbon cable with the PA20 stand ie; does it fit?.... failing that, what cable have you managed to fit? QED, Ixos etc..
  2. novaya_zemla
    novaya_zemla
    Guess I'm the only scart user then.. :clown:
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Possibly the only PA20 stand and PW6 with scart board.... But silly question which slot is scart in?
  4. Shahel
    Shahel
    im not sure wat you meant i know is a bit hard to get some cables in but i dont have that much problems so i took some pictures so you have an idea wat works
    hope these help
    [​IMG]
    [​IMG]
  5. Shahel
    Shahel
    i have a QED scart that also fits but currently stuck in the wall in my living room so cant really test atm :)
  6. novaya_zemla
    novaya_zemla
    Thanks Shahel that's exactly what I needed to see - I think I will go for the ribbon cable now that i know it fits :smashin:
    HD - My scart is in slot one (the same as the photo) slots two and three are free. Should I have fitted it somewhere else?
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    just thought if it was in slot 2 scart would fit better doesnt matter tho thor are good scarts but wont fit in alot of stuff.... i like Porfigold...good value especially at www.tvcables.co.uk
  8. novaya_zemla
    novaya_zemla
    Boy am I pleased with my self now.... :) I orderd three Profigold flat ribbon scarts just before I read your reply... I thought they would be a good compromise.
