PW6 or PW7
Discussion in 'Plasma TVs' started by bazlion, Dec 25, 2004.
  1. bazlion
    bazlion
    RS have the PW6 for £1299! good deal? I just want a good PQ to mainly view Sky+, I have a decent surround system,no other "boxes", though probably will get a DVD with component as I understand that is the best connection with a Plasma?, any advice folks.
    Go gently, I'm not clever with all the jargon!
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  3. bazlion
    bazlion
    HD.
    Cheers, but I had already trawled through that thread after doing a search, as I have already mentioned I'm not too clued up, and all I can see is something about a component connection not being on the PW7? So I am none the wiser.
  4. JonStatt
    JonStatt
    Nov 18, 2004
    3,352
    103
    +446
    There is no evidence to suggest that the picture of the PW7 is markedly better than the PW6. Also the PW7 has been introduced into the market at a lower price to start with which "may" indicate that certain components are cheaper and lower quality.
    As you said the PW7 does not have component support on the VGA socket. There are also some unconfirmed rumours that the PW7 has limitations over the PIP and PAP function. The PW7 has extra processing, more resistance to screen-burn and a 10% brighter picture. Trust me, you don't need 10% brighter!
    As the PW6 has a good track record, I would personally go for that. However, if you have the "I must have the latest" bug, then go for the PW7!
    Jonathan
  5. Bearded_Malc
    Bearded_Malc
    Aug 10, 2004
    393
    +20
    Who is RS? Do you have a URL?
    To me RS means radio spares as they used to be called rswww.com but I assume this is a different RS since I can find no plasmas on RS.
  6. GarethH
    GarethH
    Aug 31, 2000
    325
    UK
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    £1299 is a good deal if that is all you need, a VGA input panel..... however as you add the extras (which RS might not have or know about) they can soon become expensive £1549 inc mount and input board delivered to your door is a good deal as far as i can see (these dont fit easily in a car)
