pw6 or pd3000 PC input??
Discussion in 'Plasma TVs' started by danbassy, Jan 20, 2004.
  1. danbassy
    danbassy
    Jan 12, 2004
    65
    What is the pc picture like on these models? which is best for pc use?
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    You can't fit a windows desktop onto w-vga very well these days, (PW6)everyone's monitor is higher res than that, even the screen properties box in xp is more than 480 pixels tall. The screen can scale an xga image, but doesn't look so good. The PD3000 will accept xga, and it scales the vertical res. to fit. As it's quite high res, it looks quite good with that. A better bet though to use as a monitor, is the Pioneer 433mxe. True xga.
