Pw6 - Is This A Good Deal???
Discussion in 'Plasma TVs Forum' started by chris210972, Jan 22, 2005.
  1. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    see this at www.nexnix.co.uk
    Panasonic TH-42PWD6 Bundle Offer Price (Ex VAT): £1399.00
    (Inc VAT): £1643.83
    Our Bundle includes:
    1x Panasonic TH-42PWD6 Plasma Display - With VGA input
    1x Hitachi HTDK185 5.1 Surround Sound & DVD system with Freeview Digital TV Tuner
    1x Tilting Wallmount
    1x JS Technologies Scart RGB to Plasma VGA Converter (provides better picture quality than using a scart board)
    1x VGA Cable
    Just one cable to your plasma!
    i think its a good deal, is there any better?
    i cannot exceed my budget of £1700.00
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  3. Peabo
    Peabo
    What are you thinking of connecting to the TV? It only has scart with this deal.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    NEXNIX deal will only work with RGB scart (wont work with a VCR)
  5. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    telewest cable box and a pioneer 575 dvd player would be connected.
    i suppose the cable box would plug into the vga (via scart) and then i would need another socket for the dvd player (not sure which would be best, dvi, rgb scart or component).
    i don't have a sound system but the panny speakers are quite expensive so the hitachi seemed quite good.
    i have just taken back my hitachi pd325200 (i hated it) and really can't exceed £1700.00.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    AV-sales deal with Dual slot board will allow for DVD component and Cable composite (need speakers/sound tho)
  7. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    cable composite would be very poor quality, wouldn't it?
    i must admit that due to the restricted budget i am stuggelling to get what i need.
  8. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    i've also be interested in the nec vr5 which seems a very good prive but again its the sound thats a problem (nec speakers are very expensive).
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  10. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    the 37" would be better as my living room is quite small.
    which boards should i get and whats the best 5.1 set up i could bet with my budget?
    thanks
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    you have £300 for amp and speakers........ not alot.... but do able.....JUST
  12. 406lx
    406lx
    Nov 22, 2004
    895
    28
    Nottingham
    +27
    WOW
    great deal on the pwd7 from av-sales.
    Depending on HD's comments on the Panny and NEC late next week, this may be the one I am going for.
    :D
  13. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    i have some speakers so how about this,
    Panasonic TH37PW7B + BNC Component/SVHS/Composite + Denon AVR-1705
    what cables/convertors would i need to connect the cable box and the dvd to the amp and from the amp to the screen?
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    chris spot on mate (what out puts does DVD have?) and JS RGB>component converter would be ideal for feeding cable via AMP
  15. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    i have a pioneer 575 dvd player and usually connect it to my tv via component leads.
    if i get a js rgb to component convertor for the cable box to the amp, plug the dvd player into the amp using a standard component lead what cable is required from the amp to the screen?
  16. chris210972
    chris210972
    Apr 23, 2004
    384
    16
    and the 1 million dollar question would be,
    would this produce better picutres for dvd and cable than my hitachi pd325200 did?
  17. timc3
    timc3
    Feb 4, 2004
    56
    Stockholm
    I just got a PWD6 from nexnix arrived next day on a saturday(very good service I reckon and the courier was £45 + VAT in case you are interested. Currently driving it from my pioneer 575 via component to 15Pin connector and we are loving it - didn't realise quite how big it would be in my living room, but its great.
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    YES but it is bigger so will show more artifacts if you sit too close
