PW6 Input
Discussion in 'Plasma TVs Forum' started by mikatt, Sep 24, 2004.
  1. mikatt
    mikatt
    Dec 22, 2003
    178
    Hampshire UK
    +6
    Advice please I am buying the Panasonoic PW6 display and I want to feed to it a DVD recorder which is RGB Humax PVR which is RGB and a VCR which is composite am I right that I can't feed the VCR through the JS RGB - VGA unit, so can only use the Panasonic Scart board
    Mike
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Mostly right, panasonic also list a s-video/composite board, which is cheap, if you want to use the RGB/VGA converter for RGB devices.
  3. mikatt
    mikatt
    Dec 22, 2003
    178
    Hampshire UK
    +6
    MAW
    so with the s-video board I would require a scart to s-video lead for the VCR is this better than using the Panasonic scart board for the VCR and the JS unit for the DVD and Humax.
    Mike
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No different to the scart, just cheaper. And you will be connecting with a scart to composite lead, not s-video or your picture will be black and white.
