PW6 Hours Timer
Discussion in 'Plasma TVs Forum' started by novaya_zemla, Oct 17, 2004.
  1. novaya_zemla
    novaya_zemla
    Sorry to ask this again; but is there an hours counter on the PW6? I have found the service menu but there is not much for me in there! The forum search brings uo a load of dead (ish) links...
  2. Tony8377
    Tony8377
    Aug 19, 2004
    954
    Essex
    +4
    Hold down minus volume button on display. Whlist holding down the volume button use the remote control and press the button below the power button (square with a plus in it) around five times until another menu comes up. Select SD Mode from the Menu. WT = number of times switched on. PT = number of hours. Obviously don't play around in there unless you know what you are doing.
    Also see: Panasonic Plasma Faq
  3. novaya_zemla
    novaya_zemla
    That's the one - Thanks :thumbsup:
  4. swarrans
    swarrans
    Dec 21, 2001
    409
    16
    Kent, UK
    This didn't work on my PW6....
    Simon
