Pw6 gaming,pc etc
Discussion in 'Plasma TVs Forum' started by GCDB, Apr 14, 2005.
  1. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    Just a query, in the near future(when funds recover) i might decide to get a 2nd hand xbox or ps2.The pw6 i bought has at present has no extra boards and the only easy input option on my amp dsp750 yam is the s-video.Does gaming look good through this (upconvert to yuv in amp) and does anyone else play their console through s vid on a 42" plasma?
    Or should i look at trying to get an extra input on plasma eg an extra vga terminal?
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    you could always get a scart splitter so you don't need another input board.
  3. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    I could daisy through the sky box but is scart the most common connection for games consoles? Or would svid just be as good?
  4. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i think rgb scart is better but svid is not bad..dpends how fussy you are :)
  5. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
  6. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    643
    +7
    Is the softmod actually needed to get component output from the Xbox, or is it just for hidef? 've just ordered the the hi-def pack from liksang
  7. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    for hi def (soft mod)
  8. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    Both possibly. The cable is not available officially here (UK). Soft-modding allows the xbox to output 480p (and up - depending on game itself) but only on component cable out.
    Toby, you're as bad as me, why aren't you working? :D
  9. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i mustget round to doing that soft mod John.....I'm too lazy
  10. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    Really you must. SUCH good quality. If you have the correct Splinter Cell, a maxdrive, and the correct save (with built in region switcher), it takes about 5-10 minutes max.
  11. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    643
    +7
    Well, I've ordered the hidef cable pack from liksang, gonna need to get the other stuff now for the xbox to do the mod.
    I'm not at work today :hiya: (shiftworker) and am just avoiding mowing the lawns!!.
  12. JohnCCFC
    JohnCCFC
    Feb 18, 2005
    418
    +10
    Incidentally, I got my cable from whitedog.co.uk, same price, arrived next day.
    edit : Also maxdrive from there, and orig SC from my local GAME store. Must get the correct version !!
  13. tobyjuggler
    tobyjuggler
    Nov 4, 2004
    643
    +7
    Well, it's going to take me a while to get the other stuff, so there's no rush.
