PW6 Flat Wall Mount question
Discussion in 'Home Cinema Buying & Building' started by Gillious, Nov 12, 2004.
  1. Gillious
    Gillious
    Oct 28, 2003
    45
    Just ordered a Panasonic PW6, could anyone recommend me a flat wall bracket, or at least what I should expect to pay for one. So far the cheapest I've found is £160 and this seems a lot for a flat bracket (I’ve no need for a tilting one)
    Thanks in advance
  2. EpsomJames
    EpsomJames
    Jul 2, 2004
    176
    +8
  3. EpsomJames
    EpsomJames
    Jul 2, 2004
    176
    +8
  4. Gillious
    Gillious
    Oct 28, 2003
    45
  5. Gillious
    Gillious
    Oct 28, 2003
    45
  6. Johnnypanic
    Johnnypanic
    Aug 4, 2004
    201
    +16
    Brought this one -
    hxxp://cgi.ebay.co.uk/ws/eBayISAPI.dll?viewItem&category=11073&item=5732552099&rd=1
    Excellent seller and bracket was easy enough to fit (once I'd drilled the feckin holes!).
    Johnnypanic
    *** Please replace the two x's with two t's at the start of the link ***
    For some reason when I submit the message it only displays half of the link, although it looks fine in preview :confused:
