PW6 flaking suround
Discussion in 'Plasma TVs' started by mark.king, May 12, 2005.
  1. mark.king
    mark.king
    Jan 25, 2005
    192
    Bradford
    Just wondering if anyone has had a problem with the surround (mine is the charcoal) flaking? I went to dust mine the other day and a patch on the top right corner had bubbled and I could flake off the covering. I haven't cleaned with anything other than a duster. I only bought it in January so still under gaurentee from manafacturer as well as having an extended one. Any thoughts? Anyone seen the same? Cheers
  2. sheety
    sheety
    Jan 4, 2005
    28
    Had mine the same time as you no bubbling here :thumbsup: does it get direct sunlight ? because that can cause this or has the wife been using anything on it? Oh one more thing keep spray airfresheners away from the plastic this can cause problems too.
  3. mark.king
    mark.king
    Jan 25, 2005
    192
    Bradford
    Well no wife and if my girlfriend came round and cleaned I would probably faint lol. It's strange I haven't used anything on it and it does not get direct sunlight. It's only a small patch so I will leave it for now and see if it gets worse. If it does then I will have to see about getting it repaired changed. That's if anyone will belive me!
  4. Brooktop
    Brooktop
    Feb 2, 2005
    2,028
    Nottingham
    +86
    My PW6 is in direct sunlight (behind it) during the day. Can't believe I have to live like a vampire just to keep the thing in one piece. I'm sure that would qualify as 'unfit for purpose' and you'd be entitled to a refund/replacement.
