PW6 & E55
Discussion in 'Plasma TVs' started by gstadt, Nov 19, 2004.
  1. gstadt
    gstadt
    Sep 22, 2004
    270
    Cardiff
    +10
    Does anyone else find the picture a bit soft through the E55 to the PW6? I have run it into the VGA port using Van Damm BNC-Component cables. I must admit I was ecstatic when I intially set it up but have this nagging doubt that it looks softer than my Dav sc5 into a 28" CRT (or maybe I've raised the bar so much now that I need to get ever sharper pictures through spending copius amounts of cash on upgrading everything :rolleyes: )
    Also, can anyone tell me the bitsize and frequency of the D/A convertor in the E55 as I suspect that if I want to get a better DVD picture i.e. pin sharp, I may need to find a DVD player with a far better chipset for deinterlacing etc as the E55 progressive scan is no better that the internal one done by the PW6.
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Your picture problem is universal, the E55 is a fine bit of budget kit, don't expect miracles! Try a mid/high end prog scan player, you will be amazed at the difference. I love the E55 for it's features, and it's a great little box to have in any system, you have just hit on it's 'weak point', it lacks the fine edge of picture delivery to match such a big display.
  3. gstadt
    gstadt
    Sep 22, 2004
    270
    Cardiff
    +10
    MAW,
    I know its the wrong forum :devil: but what would you consider as a suitable mid-range DVD player - Pioner 575; Denon 1910; Denon 2910??
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Any of those you'd see the difference. Chuck in the new Onkyo 502 as well.
