PW6 / Denon dvd2200 no signal? Help please
Discussion in 'Blu-ray & DVD Players & Recorders' started by chaka7862, Dec 9, 2004.
  1. chaka7862
    chaka7862
    Hi guys,
    I have just connected up my new pw6 and denon dvd2200 to a BNC board and keep getting a no signal message on screen, it works fine using scart. Any ideas, help?
    Thnx :confused:
  2. andyAV
    andyAV
    I assume you're trying to use component video via BNC (and not RGB via BNC)?
    Might be that you just need to set the DVD player to output video rather than RGB - many players do one or the other at any one time - scart is RGB. Similar problems have been seen with other players and Sky+ I believe.
    When the DVD is set to video, the composite/svideo and component video outputs will likely be active and the scart inactive.
    If that's not the problem check that the BNC board is set to the correct option - you can choose in the screen menus between component video and RGB (and several modes thereof) (and this applies to the PC input connector too).
    Andy
