PW6 Connections changed - problems
Discussion in 'Plasma TVs Forum' started by PLASMABABBY, Oct 2, 2004.
  1. PLASMABABBY
    PLASMABABBY
    Jul 2, 2004
    406
    Walsall
    +15
    Hi all,
    I've had my PW6 3 months now but still consider myself a newbie.
    Today I changed my set up so that my connection to the Scart Board is as follows:
    Freeview box -----> DVD Recorder ------> Scart Terminal on PWD6
    This works fine.
    Then I have connected a cheapo £39 Acoustic Solutions DVD player to the VGA socket on the plasma via a JS Tech Scart to VGA box. I have checked the settings on the DVD player and it gives me the choice of either a YUV or normal setting - I have set this to normal BUT the picture is blue all over and suffers from RGB patterning.
    If I try and connect my video using this method I get no picture at all.
    Any thoughts or remedies would be most welcome.
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    Have you got the VGA input setup correctly to match what your feeding it?
  3. PLASMABABBY
    PLASMABABBY
    Jul 2, 2004
    406
    Walsall
    +15
    Leigh_1973
    Thanks for your response, I didn't know that you could set up the VGA inputs. How do you do this?
    Before I changed the connections the FV box worked perfectly when fed into the VGA connection.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    sounds like el cheapo DVD has poor RGB output. if it willl actually output RGB properly.
  5. PLASMABABBY
    PLASMABABBY
    Jul 2, 2004
    406
    Walsall
    +15
    Hornydragon - thanks for that.
    Methinks you are right. I'll try my Philips DVDR70 but it's not multiregion and macrovision free (to make backups) as the el cheapo one.
