PW6 Component Board/Slot 3 Problem?
Discussion in 'Plasma TVs Forum' started by Jenz, Oct 16, 2004.
  1. Jenz
    Jenz
    I reckon I may have a problem with my Component Input (BNC Board). I have it plugged into Slot 3 on my PW6 and today I tried directly connecting up my US Gamecube with Official Component Cable. I get no signal at all. Checking the Setup Menu for Input 3 it is correctly set for Component.
    Any ideas? Does anyone else have a component board running in slot 3 successfully? Note this is the first time I have tried it so I am wondering if the board itself may be faulty?
    Regards Neil.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    check your manual the 3 slots cannot all take all boards and slot 3 can only accept certain boards IIRC perhaps swap the boards in 1 and 3 i am pretty sure manual tells you which boards can go where assuming its a 42/50 PW6
  3. thudspud
    thudspud
    Mar 28, 2002
    2,399
    Sheffield
    +130
    slot 3 definately accepts a component board as I have one in all three slots so don't know what to say other than check the connections!
