I'm thinking of taking advantage of the current Richer sounds PW6 offer i've seen in the newspaper today. Could anyone let me know if this set up is at all feasible with the following equipment. PW6 + Toshiba SD-240 DVD +Sony Freeview STB, I know the PW6 has one RGB Scart so I hope to connect both of these via this input. As for sound I have a Marantz pm-66se stereo amp connected to a pair of floorstanding speakers is it possible to connect the amp to the plasma/DVD/STB combination or is the only option to use the spring-clip connections directly from plasma->speakers.
Please note I haven't got the freeview STB yet (I just saw a few posts where it was recommended) so I can change this item if another STB makes it possible to hook all this equipment together. Also, this is just a temporary set up to get me up and running (especially if the speakers have to be directly connected to the screen) and i'll get hold of an input board once i've had the chance to suss it all out properly.
Finally what cables do I need to connect all the bits together, obviously i'll need a wall mount of some sort (as a plasma lying on the floor against a wall with two toddlers treating it as a drawing board is not a good idea ). Ok thanks in advance for any replies......
Scott
Scott
