We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
pw6 and vga input
Discussion in 'Plasma TVs Forum' started by rab4169, Nov 4, 2005.
  1. rab4169
    rab4169
    Dec 12, 2004
    533
    i have a panasonic pw6 , it came with 1 scart and 1 vga with audio input.
    my vga is taken up with pc and i have ordered the rgb to vga box today ,
    what is the best way to connect this to plasma? should i buy another vga input card for plasma which i think is £70? will the plasma work with 2 vga input cards . i know its a bit late as converter is ordered but will this make a big difference over the scart input
    thanks
    robert
  2. don-tucker
    don-tucker
    Aug 9, 2005
    298
    Hi,Just been through the same situation,read my post Plasma PQ,you will find the converter box hell of a better picture over scart.I don't know the answer to your other question as I haven't worked out how to plug in my pc now I have used the VGA input.
    Don
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Another PC input is the way. £70 seems expensive for it, it's usually the cheapest input board.
