pw6 and dmre55 component connection scan lines noise
Discussion in 'Plasma TVs' started by sacd, Nov 8, 2004.
  1. sacd
    sacd
    Feb 19, 2004
    295
    Cardiff
    As the title suggests, I have just bought a dmre55 and connected it to my pw6 via component connection. However, there appears to be reddish scan line type noise in the black areas of the picture.
    I also have an old pioneer 747 dvd player and that exibits no noise at all.
    Does anyone know about this problem with the dmre55?
    Any help out there before I take it back?
  2. EpsomJames
    EpsomJames
    Jul 2, 2004
    176
    +8
    I'll connect my DMRE55 to my component board tonight and let you know if i get the same problem.
    Which terminal board are you using, or is it the VGA input you are using for component.
    Have you checked that you have progressive scan enabled in the settings on the DMRE55?
  3. sacd
    sacd
    Feb 19, 2004
    295
    Cardiff
    Thanks for the reply,
    I'm using the dual slot board and the prog scan is turned on. If fact prog scan seems to make little difference to the problem.
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    It's definitely not a universal problem. For some installations, using the E55 to convert RGB scart from, say, sky, gives a rather dull picture, but I have not seen any problems like you describe. Dodgy cable? You could laso try re-seating the board if you are using one.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    are you using RCA to BNC adapter things or a premade cable?
  6. guli
    guli
    Sep 3, 2004
    384
    16
    horny,
    i have tested some gold plated rca to bnc adapter things and a premade cable (both belden 1694A) on a pwd6 with the dual board.
    no discernable difference
    Alex
    Alex
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Just wondered if it wasn't a clean connection causing this???
  8. sacd
    sacd
    Feb 19, 2004
    295
    Cardiff
    Don't worry, it's all ok.
    I had some of the levels in the advanced settings turned up too high.
    Interesting that the interlaced picture on my pio 747 is much much better than the progressive picture from the panny e55.
    Thanks for the replys everyone!
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    747 is a hell of a player tho and E55 is a budget DVDR......
  10. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    And don't those speakers emit smoke during action movies? The 747 is likely to outperform the E55 even if you used s-video on the 747
  11. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    I thought the 747 was a jumbo jet, god I'm thick!
