Pw6/7 Component Card Availability ?
Discussion in 'Plasma TVs Forum' started by bladerunner8801, Nov 26, 2004.
  1. bladerunner8801
    bladerunner8801
    Jun 4, 2003
    397
    UK
    +29
    Is there anyone else out there struggling to get hold of the Component card for the PW6 or PW7 i ordered mine from Sound & Vision in Bolton on Sept 2nd still not arrived keep telling me theres a nationwide shortage of component cards for these plasmas?
    Regards Dale.
  2. Member 6435
    Member 6435
    Dec 18, 2000
    1,518
    Tunbridge Wells
    +324
    Dale
    There is indeed a shortage of component boards with RCA connectors as Panasonic have not had any now for a number of weeks. Component boards with BNC connectors are, however, readily available. There is no quality difference between the two boards - just the connection type. Sound & Vision should be able to source these and also provide the necessary cable you require i.e. 3RCA - 3BNC.
    Regards
    Alastair :hiya:
  3. Mr Ess
    Mr Ess
    Oct 27, 2004
    1,303
    48
    Preston, Lancs
    +39
    I had horrendous problems getting one. In the end I went to Richer sounds in Watford and collected one of their two in stock last weekend. Call a richer sounds store and ask them to check group stock on the card. They have none in the warehouse, its just the stores. When I asked that, they found 5 in guilford, 2 in watford and a couple at a couple of other stores. You may be in luck if you are quick (and willing to travel as they won't post unless the warehouse has them). :thumbsup:
  4. bladerunner8801
    bladerunner8801
    Jun 4, 2003
    397
    UK
    +29
    Thanks for the replys chaps, the component board i ordered was part of the package deal i did with Sound & Vision so i got a good price, iv'e also had Mark Grant construct me a high quality RCA to RCA component lead so BNC would mean sending the cable back for alterations, i will wait a little longer see if these things eventually arrive???
    Thanx again
    Regards Dale
  5. ihan
    ihan
    Sep 10, 2004
    655
    28
    Stockport
    +25
  6. bladerunner8801
    bladerunner8801
    Jun 4, 2003
    397
    UK
    +29
    Ihan
    Yes i know what you mean i may have to go this route if the boards do not turn up, i was just curious if anyone else was having the same difficulty sourcing the Component boards, it seems that it is a problem at the moment, i will give them another couple of weeks then go for a BNC board.
    Regards Dale.
  7. calmac
    calmac
    Aug 16, 2004
    17
    Forget about it lads I tried in vain to get any kind of input boareds on friday all i could get where the dual slots boards and i scoured the net trying to find a supplier - no one has them in stock but they all say they will be in next week.
    calmac
  8. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    Got my 2 input boards no problems last week when I picked up my plasma.
    PM me your details bladerunner if you still havent got hold of one and I can check availability for you tomorrow.
  9. matt bellamy
    matt bellamy
    Jun 19, 2004
    230
    16
    Whats the difference between RCA and BNC. My DVD player has component video out and it says Pr, Pa and Y next to them. My AMP also has component in/out with Pr, Pa and Y. Which type are they, RCA or BNC?
  10. guli
    guli
    Sep 3, 2004
    412
    16
    none of the either
    RCA and BNC refers to the physical dimendions/shape of the connection.
    BNC is twist lock, RCA is just a typical plug
    Your dvd player and amp will most likely NOT have BNC connections
    Alex
  11. matt bellamy
    matt bellamy
    Jun 19, 2004
    230
    16
    so are the RCA connector ends the same as phono connectors? If I got a plasma with RGB scart socket could I get a cable that goes from RCA component to RGB scart to connect the component from AMP to Scart on the plasma?
  12. bladerunner8801
    bladerunner8801
    Jun 4, 2003
    397
    UK
    +29
    Matt
    I did get a good deal on the Component board despite the fact that i have not seen it yet, lol, since most people are struggling to get them i will hold out a couple of weeks more see what happens? Sound & Vision say they are waiting for the shipment from Panasonic Japan, odd though when there new PW7 has just hit the shops and uses the same board, you would think they would have adequate supplies?
    Regards Dale.
  13. guli
    guli
    Sep 3, 2004
    412
    16
    matt,
    rca IS phono. RCA (recording company) recreated them.
    No, you cannot connect RGB scart to component, not in the way you mention. You need a component board on your plasma.
    Alex
