Rob100
Hi all,
I'm still battling trying to work out how I will connect my kit to the PW5B. I'm looking at connecting my DVD to the RCA sockets through a JS RGB-VGA box and my PC to the VGA socket. If I was to do this and connect my Sky box, Pana E30 etc to the s-video socket (switched through my AV amp) would I be sacrafising too much PQ?
What I really need is a RGB scart switch box that connects to the switched composite inputs on my amp, so when I select SAT, DVD etc on the amp the RGB scart switch detects the change of input and selects the correct RGB scart input. Did I explain this very well? I don't know if this is possible and I'm sure no-one makes such a thing - maybe an idea for a new JS box
Can anyone recommend a half decent scart switch box? I notice Lektropacks do something called a "Quattro" that sounds quite good...
Rob.
Rob.
