PW5 Service menu
Discussion in 'Plasma TVs Forum' started by thedude, May 5, 2005.
  1. thedude
    thedude
    Oct 18, 2004
    9,895
    Swindon
    +2,007
    can anyone tell me how to get into the service menu, and how i can find out how long my screens been on for?
  2. nathanf
    nathanf
    Mar 17, 2003
    52
    yeah I searched the forum and what I found didnt work for me... (Hold down volume - and press the [+] key)
  3. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    for the pwd7 you press the [+] key three times......and also make sure you don't have your hand in the way of the infra red reciever on the screen!!.(it's easily done).....no idea if this is the same for for pw5 though.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I am 99% its the same (its the volume button on the front panel of the plasma not the remote) and not sure if it works with tuner conencted...
  5. Enquirer
    Enquirer
    I think its the same too
    Press and hold down the volume down button on the front panel and then press the status button three times quickly(within 1 sec) This takes you into the CAT mode.
    You then select the SD mode by UP and Down on the remote then press the action button on the remote
    PT is the cumulative Time for power on condition measured in hours
    WT is the power on counter.
    To exit the CAT mode access the ID mode and switch off the main power
    [​IMG]
    [​IMG]
    As always if you dont know what your doing or not confident dont mess with it.You can mess things up if you press the wrong sequence of buttons.
  6. nathanf
    nathanf
    Mar 17, 2003
    52
    ^Yes! That worked.
    Turned out I had my hand covering the IR sensor.
    721 Hours?!!?! I knew it was second hand but JESUS!
    BTW that was very scary I was scared I was gonna press something wrong
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    721 hours is nothing mate its good for 30,000
  8. nathanf
    nathanf
    Mar 17, 2003
    52
    :thumbsup: Thanks for putting my mind at rest.
    I thought their lifespan was 1000 hours.
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    1000 hours or 3 hours a day, dead in under a year!!!!!!at £3k (price as new) thats very very very expensive TV
  10. thedude
    thedude
    Oct 18, 2004
    9,895
    Swindon
    +2,007
    parameter 1390
    pt 4687
    ok i tried figuring out what they meant but you guys understand everything far better than i do.
    Thats the readings fro my display
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    switched on 1390 times. cumulative time "on" 4687 hours
  12. thedude
    thedude
    Oct 18, 2004
    9,895
    Swindon
    +2,007
    damn thats alot of viewing. How long u get outta these boards? i thought panasonic said 11k hours? is it up to the 30k?
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    30-40,000 for a PW5 they upped it to 60,000 for the PW6 the PSU etc will fail before the panel wears out
  14. thedude
    thedude
    Oct 18, 2004
    9,895
    Swindon
    +2,007
    oh thats good to know i wont have to be buying another tv in a long long time then :D
  15. Taz69
    Taz69
    Apr 15, 2002
    3,272
    Bristol
    +306
    Dude, where did you get the plasma from and at what price m8, cheers
    Taz
  16. thedude
    thedude
    Oct 18, 2004
    9,895
    Swindon
    +2,007
    i work at comet, so i got it from there for £980 with tuner box
  17. Taz69
    Taz69
    Apr 15, 2002
    3,272
    Bristol
    +306
    cool,
    cheers m8
    Taz
