pw5 pc switcher box
Discussion in 'Plasma TVs Forum' started by jhanna, Feb 12, 2003.
  1. jhanna
    jhanna
    I have today purchased pw5 42 sound peace of kit.
    connecting through js component box to vga pc in i did not get rca board with my panny only the tuner teminal board.
    i would like to no if you can get a switcher box vga without loss off quality to imput pc and dvd and sky to swap beetween both.
    also if i get scart rgb to componet r g b h v/snc will this work on my new rca board when it arrives this will save me getting a switcher box
  2. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    Sorry m8, but this is a very confusing post :confused:
    Can you explain again what you are trying to do?
    I am really puzzled with regards to "connecting through js component box to vga pc in" - you would not use the JS RGB2YUV box to connect to the VGA input - for that you would need the RGB2VGA box.
    I think you will find that having the tuner connected to the tuner terminal board will disable the VGA input.
    Rob.
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Something like an iScan Ultra will switch these three inputs into single VGA socket, via a remote control; and will progressive scan DVD and Sky resulting in a much better picture.
    This card will give you some other inputs: RGBHV or component and s-video and composite. And you will still be able to use VGA.
    If you do not want to compromise quality you will have to get a switcher.
    Otherwise, you could connect: PC to VGA; DVD player to RGBHV / component (depending on output from your player); and Sky to S-Video (although you may have to get an RGB scart to S-video converter).
    StooMonster
