PVR8000T 2 hour instant record limit??
Discussion in 'Digital TV & Video Players & Recorders' started by disastermaster, Jun 25, 2005.
Tags:
  1. disastermaster
    disastermaster
    Dec 10, 2002
    48
    Hi , I've been using my PVR8000T for about 6 months now and I'm quite impressed. But I tried something recently and I dont know if there is a fault with my machine or not. If I press the record button as I am watching a channel, the PVR8000T will only record for 1 hour 59 minutes and then stops. Is this correct or have a setting wrong somewhere?
    TIA Disastermaster
  2. domtheone
    domtheone
    Nov 23, 2004
    14,738
    Nottingham
    +3,505
    Unfortunately I don't have the answer for this.
    I have this model and I hardly ever press the record button.
    I've had it on timer record for as much as 8 hours.
    The buffer that records while the unit is on usually lasts an hour or 2 so I can only assume that instant recording has the same restrictions??? :confused:
  3. phillem
    phillem
    Nov 22, 2004
    20
    Yes this is normal, if you want longer record times, each press of the record button will give you different times.
