PVR: overwrite recording time (e.g. LM760S)
Brille
if I record a TV film with the bulit in PVR (with USB HDD) using the EPG I get a problem if the film starts later than scheduled. In this case the end is missing on the recording :mad:
So I like to overwrite the recording end time and let it run a few minutes longer. Unfortunately I cannot find a possibility to overwrite these timings or create an entry on the recording list completely manually.
Do you have an idea?
My TV is a LG 47-LM760S
Thanks,
Brille
citywalker
Use your magic remote and click Record, if tv already records show. Special record options menu pops up and you can choose ending time.
But if you choose show from EPG to record, doesn't menu pop up, where u can choose end time?
Sorry, i have different tv and menu with time options just pops up
Brille
Thanks for your quick reply!
Indeed a start- and end-time modify pop-up box appears in the options, but only the start-time is editable. The end time is greyed out...
Do you have any further ideas?
Cheers,
Brille
citywalker
Cheers,
Brille
Ok, then you have to go to:
EPG - Manual Timer - date menu opens up - choose day where your record is - clik OK - menu opens up - Once, Weekly etc, choose what you want - clik OK - NOW YOU CAN EDIT START AND ENDING TIME
Hope this helps
