It would be worth checking with Aria if this one is a Vestel T825 with Series Record or the earlier T816 with Accurate Recording but no Series Link. Digihome used the DTR80 model number for both these versions.This "refurbished" one (I'm convinced they dont refurb them at all, but I've got one I've had since March 07 still going strong) from Aria will come out a bit above your budget (Aria are devils for slapping VAT on everything during checkout) but it's the nearest I can find and Aria will collect and refund if you don't get on with it or if it's faulty. Try eBay if you don't want to go for this one.
Digihome DTR80 80GB Freeview Plus TV Recorder - Aria Technology
Support forum here: Digihome - Digital Spy Forums
clemenzina
Yes most Logik(Currys) branded PVRs are Vestels but they did sell TVonics units under ther brand for a while about a year ago.I think Logik PVRs are Vestel clones but you need to check the specific model, look for the T8** version number.
clemenzina
It's a good thing if it's Vestel, provided you don't get a glitchy one. I would go for that one if you can get it within budget.
The only thing is, I don't understand "No of Scarts 1 To enable you to connect to other equipment such as a DVD player, video or games console" - I'm sure it should/will have 2 SCART sockets.
PayPal will support you if you get a faulty one.
Just noticed (Firefox isn't displaying eBay well these days) it is "missing remote" - I happen to have this one on my Watch List (another £9 to take into account):
Remote Control DIGIHOME PVR80 PVR160 PVR160TW DTR0207 on eBay (end time 12-Sep-09 09:03:18 BST)
clemenzina
Yes, the Logik LPVR168 is a Vestel T825 so will have Series Record.If you know a seller is reliable then go with him. BUT MAKE SURE YOU GET THE RIGHT MODEL NUMBER - I'm pretty sure the one in your original link does Series Record, a lot of sellers are not giving the full specs - one of them says "Google it" and the result is useless.
clemenzina
