PVR, DVDR Cabling Combo - Does this work ?
Discussion in 'Plasma TVs' started by tetrarch, Sep 12, 2005.
  1. tetrarch
    tetrarch
    Jan 20, 2005
    60
    I'm delighted with my Panny TH42PWD7. It's time to upgrade my ancilliary kit.
    For the time being I'll keep my Freeview box with a view to upgrading to Sky+ when I get the green light from Mrs Tet.
    I want to replace my VCR and DVD player with a SKY+ box and a DVDR.
    The DVDR I am looking at is the Panny DBRRES20D (Freeview Model)
    I have my component cable and terminal board installed, so I now have two inputs to the screen (for PIP,PAP and POP)
    I have all the audio sorted out, but wuold like to know if this will work:
    Split CO-AX into FV box and DVDR
    FV Box to Screen SCART (via Quintro)
    FV Box to DBRRES20D via SCART
    DVDR to Screen via Component
    Does this set-up have the requisite connections for me to watch two FV channels at once via PIP/PAP/POP ?
    Can I watch two FV channels and record another ?
    In the future I will swap out the FV Box for a SKY+, will this pose any problems ?
    Thanks for the help
    Regards
    Tet
