PVR > Component & VGA Help please!?
bittermace
OK well first things first thanks for taking an interest in helping me I have most of this setup planned out except for a couple connections that I could Really use some help with
Diagram Full Size
1. As you can see from the picture I have created I want to be able to split my VGA signal from the Xbox 360 to the VGA on the monitor and the Component connector on the Comp Switch.
The Orange parts in the diagram are the connections I need help with.
Would I need a cable for this or a converter/ adapter box ?
2. Then from the PVR I need to be able to convert the signal back from Component > VGA into the VGA Splitter.
Would this also need a cable or a converter/ adapter box ?
If you can follow the diagram I want to be able to play the xbox 360 on its original VGA resolution but be able to flip the VGA switch just to check and make sure I am recording the right Comp channel (Xbox 360, DVD, Wii) etc. any help people can give would be greatly appreciated/
