PVR-9200T standby display
Discussion in 'Digital TV & Video Players & Recorders' started by spl23, Oct 29, 2005.
Tags:
  1. spl23
    spl23
    Jan 9, 2004
    2,672
    103
    +385
    One thing that does bug me about the 9200T, like the 8000T before, is how bright the display is when in standby. I use the PVR in my bedroom, and the displays on both boxes when they are showing the clock are almost bright enough to read by! As a result, my 9200T (like the 8000T) has just had a large patch of black tape applied over the display, rendering the display invisible and making the front panel look a mess, but at least allowing me to get some sleep.
    I've emailed Humax to ask if they could make the clock display in standby an option in one of the setup menus, as it was on my old Panasonic VCR - would anyone else find this useful?
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    Why so drastic an action. Surely a black sock just draped over the clock display would suffice or even placing a piece of cardboard up against it.
    Try some Quality Street cellophane sweet wrappers (various colours) for reducing the brightness.
  3. spl23
    spl23
    Jan 9, 2004
    2,672
    103
    +385
    Have you tried that? The display on this thing is *bright*! I find it very difficult to sleep in anything other than total darkness - enough light will get around the sides of a sock or piece of cardboard to be annoying. The tape actually looks neater, and you don't really need to be able to see the display when it is switched on - I'd just like the option to turn it off tidily in a menu.
  4. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    +296
    Yes - I do have this 9200T and it is upstairs and the clock display doesn't bother me. I turn off at the mains when not using it. Same as I do with all my electronic equipment.
  5. merlynn
    merlynn
    Why not get a strip of dark coloured perspex and stick it over the display with double sided tape
  6. rich_jtg
    rich_jtg
    Mar 13, 2004
    241
    +13
    We have some wide, very dark red coloured tape at work, which is used to prevent UV light reaching printing plates *yawn*.
    I haven't got a clue what it's called, but I use it on my clock radio display, and it works a treat - kind of reduces the brightness by 70%.
