PVR-9200T - "cold boot" every time it turns on?
Discussion in 'Digital TV & Video Players & Recorders' started by spl23, Oct 29, 2005.
Tags:
  1. spl23
    spl23
    Jan 9, 2004
    2,672
    103
    +385
    My PVR-9200T behaves differently from my old PVR-8000T.
    With the 8000, you only got the "loader" progress bar the first time you powered it up after turning it off at the mains; thereafter, it came on pretty much instantly.
    With the 9200, the "loader" seems to run every time you take it out of standby. Also (probably related) every time you take it out of standby, the EPG is empty and it takes a few minutes to be populated - the 8000 used to remember it's EPG while in standby.
    Does anyone else's do this, or did I get a faulty one?
  2. merlynn
    merlynn
    I think they all work this way mine certainly does
  3. Damon
    Damon
    Oct 5, 2005
    266
    Croydon
    +4
    My 8000T always used to run the boot screen when I took it out of standby but it was very quick, this one is also quite quick but there is a blackscreen pause after it is loaded and the channel is displayed.
    I haven't noticed the EPG having to reload, will have a look
    Damon
