Pvr 8000t
Discussion in 'Digital TV & Video Players & Recorders' started by neobristol, Sep 21, 2005.
Tags:
  1. neobristol
    neobristol
    Sep 21, 2005
    20
    Emigrating to Australia 28th June 06
    I have the above freeview box, and id like to transfer saved programs to my hdd on my pc, i notice the box has an RS-232C plug what is this for? can it be used for connecting to pc they are in the same room?
    thanks from Dominic
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,321
    Somewhere in South Yorkshire
    +5,679
    Nope. Service use only. You'll need an analog video capture card on your PC. Unless you want to dismantle the Humax and remove its Hard Disk.
  3. neobristol
    neobristol
    Sep 21, 2005
    20
    Ive taken it apart plugged it into my pc, not finding it in 'my computer' but it is present in computer management, but the partition is not recognised, how do i go about get programs off of it?
  4. mildred
    mildred
    You cannot get programs off the Humax HDD. They use a special proprietry format.
    Just use a SCART cable to copy across to your recorder.
