PV500B to ES10 (oh and some Sky+!)
Discussion in 'Cables & Switches' started by ColdKilla, Jul 30, 2005.
  1. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    I have recnetly ordered the PV500 screen which comes with the free ES10 DVD recorder. Does anyone know a) if this comes with a decent lead to connect the two or if not b) what is the best way to connect the two and if so c) where I can buy such a lead.
    Also to add to this I will be connecting Sky+ box to the setup presume rgb via scart is the way to go here?
    Cheers,
    Maek
  2. Freddo14
    Freddo14
    May 11, 2005
    27
    3
    my es10 came with composite leads (basicly useless) get some nice component leads for it.
    like these:
    tv cables
    or if you fancy spending a little more and waiting a little longer but want much nicer hand-made cables:
    heartland cables
    or look for mark grants cables on these forums in the powerbuy section somewhere, those get a lot of praise here.
    in this thread
    hope that helps
    ps: yes rgb scart is best for your sky+ lots of people recomend thor ones that you can get for about £20 from maplins I think.
    maplins
    you can probably get those scart leads cheaper if you shop around.
  3. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    Thanks for the really informative reply - much appreciated - now I can get all my leads ready for when it all arrives - Thanks again
