PV500b - HTPC resolution?
Discussion in 'Plasma TVs Forum' started by stuartam_81, Jun 12, 2005.
  1. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    Hi guys, just testing my Panny PV500B connected to my HTPC via SVID (only till i take it off the wall and swap out the cables ) and i cant get a good picture.
    i have tryed 1024x768 and its ok but nothing special its actually a little blured, so was wondering what res the other 500 owners are using?
    i have got powerstrip installed on my htpc ( running an ATI 9550 ) has anyone done a custom monitor for the pv500 yet?
    want to get it looking mint so i can try out some HiDef demos :D
    best regards
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    you need to connect it to the vga for a cystal clear picture, 1024x768 res.
  3. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    thanks m8, guess i will have to wait ttill i take it off the wall and swap out all the cables, im going to use a DVI to HDMI cable, just waiting for some more cable to arive on tuesday.
    best regards
