PV500 with Wall Bracket - ok for my Alphason stand?
Discussion in 'Home Cinema Buying & Building' started by AndyH, Aug 8, 2005.
  1. AndyH
    AndyH
    May 7, 2002
    620
    +21
    I'm in the market for a 37" PV500, and already have the Alphason ADP3/96-s stand (with the swivel pole).
    Will I just need the wall bracket version of the PV500 to attach it, or do I need anything else I'm not aware of...
    Help appreciated!
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,062
    2
    4
    137
    Garstang, Lancs
    +1,597
    Just some M8 rawl bolts for mounting it.
  3. AndyH
    AndyH
    May 7, 2002
    620
    +21
    Winner - thank you :)
  4. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    185
    If you are off to get Rawl bolts - make sure you have a 14mm masonary drill - these things need big holes!!
  5. bkny
    bkny
    May 11, 2005
    104
    16
    i used 6 M6 (instead of 4 M8) bolts to put up my 42", they seemed more than adequate and needed a 10mm drill bit if you don't want to make big holes, the minimuym hole depth for these were 55mm, which was just about the right depth for my wall aswell
  6. AndyH
    AndyH
    May 7, 2002
    620
    +21
    Well, in the hope it might help someone else - The Panny 37" PV500 does not go on the Alphason ADP3/96-s stand.
    At least they didn't think it would in the shop, and that was after much tape measure action.
    Hey ho, no swivel pole stand for me. Guess its a standard stand and pedestal job.
    Thanks for the replies though.
  7. Siro
    Siro
    Nov 21, 2005
    217
    Edinburgh
    +5
    Just last night myself and my mate securely fixed a 37PV500 to the ADP3/96-PB stand.
    Looks very good and the swivel action feels sturdy. It was a little tricky because of the Panny's fat arse but we got there. Even Alphason said themselves it was compatible.
    I'll post some pics when i get hold of my Digi Camera.
  8. AndyH
    AndyH
    May 7, 2002
    620
    +21
    Oh - I'd forgotten about this thread... because I've posted my pics elsewhere. You're right - my 37PV500 is sat on one too.. turned out the shop didn't know what they were talking about :)
