pv500 with cabinet owner help
Discussion in 'Plasma TVs' started by ado, Jul 12, 2005.
  1. ado
    ado
    Nov 6, 2003
    192
    +6
    how have you lot squeezed an amp, dvd player, free dvd recorder and centre speaker all in the one cabinet.
    had the pio 575 got a better picture output than the dvd recorder if so i could loose the 575.
    another option is for me to buy the pio vsx502-s slimline amp but that would mean throwing away a perfectly good amp.
    any thoughts
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    thats what happens when you buy a "telly"!
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,062
    2
    4
    137
    Garstang, Lancs
    +1,597
    Another smartarse comment from the 16 year old chedmaster :suicide:
  4. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    does it really matter how old i am, old man? :rotfl:
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,062
    2
    4
    137
    Garstang, Lancs
    +1,597
    Your point is?
  7. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,062
    2
    4
    137
    Garstang, Lancs
    +1,597
    It does when you post immature and unhelpful comments.
  8. Korum
    Korum
    Feb 19, 2005
    4,281
    Stockton-on-Tees
    +704
    I raised the bottom shelf so my amp fits on the lowest shelf,this leaves quite a narrow middle shelf but my pio 575 fits in there,I also tried sky+ box on middle-it fit but the cable tidy at the back of the shelf had to be removed.I then put my Sky+ box and centre speaker alongside each other on the top shelf.
    I suppose it all depends how wide your centre speaker is and whether you go for a 37'' or 42''.
  9. av2diefor
    av2diefor
    I noticed the cabinet on the 42" 500 is tight for av equipment, i know if you have a decent size amp its impossible (heightwise) to fit it in.
    I know if you already have a cabinet you are limited, best option is to buy a ped and a av rack such as an alphason.
  10. London Town
    London Town
    Jun 10, 2004
    2,066
    +152
    Just what I have done - a week of the cabinet and I've had enough :( got a refund on the cab and purchased a ped + top quality TV cabinet....
  11. av2diefor
    av2diefor
    Good for you, personally i think the side flanks of the cab look too wide,they pinch quite a bit of storage space.
    not a problem on the 50" mind, but the extra 2k is :)
  12. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    but pointless threads are fine :rolleyes:
  13. samjet
    samjet
    Jan 1, 2005
    1,339
    38
    notts
    +5
    i had this problem with the original viera cabinet stand - posted a thread on it a while ago
    basically its pretty much impossible to get reasonably sized components within the cabinet especially any 'decent' centre speaker
    i spoke to panasonic and reading between the lines it could be said that the cabinet is designed for all in one av systems :D
    however, in fairness to panasonic they collected the stand and gave me a refund to the value of the pedestal stand that i had bought (could get no more as the cabinet stand was 'free' with the tv) - then had to buy an av table at more expense :(
  14. ado
    ado
    Nov 6, 2003
    192
    +6
    has anyone compared the free dvd recorder v there own dvd player (i have the 575) how do they look picture wise
  15. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Have a look at optimum stands.You can specify what height shelves you need and for less than what the pv500 stand costs.Ive gone for the av300 mk11 costs around £375 with chrome supports and they do look very good.
    Discount electrical uk are doing buy now pay 12 months later which is good after having just splashed out £2500.
  16. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Ive tried the recorder against my sony 900v dvd player and the old sony wins on picture but slaughters it on sound.Think this maybe due to it only having optical connection (no coax connection).
  17. ikon66
    ikon66
    Mar 22, 2005
    400
    Tyne & Wear
    +8
    how is it immature and unhelpful? only a valid comment on the pifalls of buying a tv with stand, when I bought my pio and floor stand I made sure that the kit I had was going to fit :hiya:
  18. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,062
    2
    4
    137
    Garstang, Lancs
    +1,597
    He wasn't referring to the stand in his comments
  19. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    i was referring to the stand actually mal. buy a telly, have a telly sound system that will fit on a telly stand. buy a panel, and customise it how you want. that cabinet is THE biggest rip off ever. its ugly, fat, and stores next to nothing, whereas an alphason look alike can be got for £100 and a proper one for not much more. dont call me "he" either, its chedmaster.
