PV500 "WIDE" notice
Discussion in 'Plasma TVs Forum' started by Tuxedo, Aug 21, 2005.
  1. Tuxedo
    Tuxedo
    Jul 6, 2005
    16
    Hi All,
    Just noticed an annoying habit of my Panny PV500. The ""WIDE" notice which normally flashes on for a few seconds at the beginning of a programme/ad etc, has decided to keep appearing and disappearing all the way through any programme. Any oneelse had this or can suggest a fix - would be good to hear from you.
    Ta. Tuxedo
    Panny PV500 & Panny SCHT1500
  2. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    Don't use 'panasonic auto' aspect ratio mode, I set my aspect ratio mode to 16:9 when I got mine nearly 6 weeks ago and I've never seen anything like that on any channel.
  3. xenon
    xenon
    May 7, 2003
    65
    11
    +3
    Anyone know what's up with Channel 5? It seems they keep dropping the widescreen signal. Also each time it's sent, it overrides whatever picture mode the PV500 is in.
  4. Worm
    Worm
    Mar 4, 2003
    246
    +8
    Its only on channel 5.. panasonic auto has no bearing on it.. started thursday nite on mine.
  5. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    yep same here on channel 5, no matter what format ive got selected it always flashes wide non stop... luckly i got sky so can use 5 on there which has no problems
  6. Xpilot
    Xpilot
    Aug 6, 2005
    9
    Yes the problem only affects Channel 5. Happens regardless of the aspect ratio selected.
    My DVB software version is 1.64. If anyone is not getting the problem what software version do you have.
    The flashing WIDE signal does not happen if I use a PVR tuner for channel 5.
  7. cliveuk
    cliveuk
    Aug 20, 2004
    524
    28
    Folkestone, UK
    +45
    1.64 here to
  8. Tuxedo
    Tuxedo
    Jul 6, 2005
    16
    Hi All,
    I think a lot of you are right. It does only seem to present itself on Chann 5 and I think it may well have been only since last Thursday. At the moment, the only way I've been able to avoid it is by switching my Panny SCHT 1500 on (DVD player/Home Cinema) and watching the Telly through that via component lead.
    Look forward to hearing about a fix for this.
    Cheers.
    Tuxedo.
