PV500. Where is the HDMI Input
Discussion in 'Plasma TVs' started by Bonzodogdick, Jun 22, 2005.
  1. Bonzodogdick
    Bonzodogdick
    Dec 1, 2004
    171
    16
    Cloud 9
    Sounds a daft question, but bear with me.
    Ordered my PV500 from AV sales, but we're still waiting for the wall brackets, so havent received the set yet. In order to buy the correct lenght of HDMI-HDMI cable to connect it to my DVD player, can anyone tell me where the input is located at the rear of the plasma? ie: Middle bottom, Right side halfway up etc?
    Thanks :thumbsup:
  2. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    the hdmi input is just above the scart sockets at the back, about 10cm from the bottom of the screen. To be honest all tellies seem to have their inputs almost at the same exact position at the back!!
  3. greyhorse
    greyhorse
    Apr 16, 2005
    445
    Located on the right side of the screen as you would view it mounted, around half way up.
  4. Bonzodogdick
    Bonzodogdick
    Dec 1, 2004
    171
    16
    Cloud 9
    THANKS FOR THE REPLIES GUYS, BUT YOUR ANSWERS DIFFER!
    SO WHERE IS THE INPUT? 10 CM FROM BOTTOM, OR HALF WAY UP ON THE RIGHT?
    SORRY ABOUT THE CAPS LOCK, IM NOT SHOUTING :D
  5. thornton
    thornton
    Apr 18, 2005
    263
    +10
    Can't see why this is a big deal!! I had to unplug and re-plug the HDMI last night as I finally got my pedestal stand. Looking from the back, but working from memory, it is about 10-20cm from the bottom, and I recall it was just to the right of the middle!!
    But why is your length of cable quite so sensitive??!! My DVD player is just below the telly on the stand, and the 1m cable is more than long enough.
  6. neilmcl
    neilmcl
    Oct 29, 2004
    6,217
    103
    Nottingham
    +290
    If you read his post he infers that he's going to be wall mounting the display, hence the need to know what length cable he'll require.
  7. kumamoto
    kumamoto
    Sep 2, 2003
    1,100
    38
    Watford
    +17
    i think greyhorse was having a laugh!!!
