PV500 Warranty Card........
Discussion in 'Plasma TVs Forum' started by aliboy, Jun 23, 2005.
  1. aliboy
    aliboy
    Hi my new UK 42" PV500 Plasma didn't have a warranty registration card with it (something that is stated in the various documentation that arrived with it)
    How do I register my Plasma with Panasonic? Or do I not need too?
    What happens if there is a problem with it? Do I just go back to the store I brought it from?
    Has anyone else who got the UK version of this plasma have their warranty card missing?
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    I think there was something saying that theres isn't a warranty card any more. Have a look through the paperwork again, it was a loose piece of paper.
    I have never filled in the warranty cards.
  3. aliboy
    aliboy
    yeah, that is what i had.
    So is the plasma registered (serial number etc) with Panasonic via the store you brought it from? In case of future problems?
    I never normally fill those cards out either, but on a 2k set its a different matter! The more cover the better!
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,194
    2
    4
    137
    Garstang, Lancs
    +1,625
    The shop should sort all that out.
    If you have the plasma and the receipt then you should be covered.
  5. MrNPG
    MrNPG
    Apr 13, 2005
    764
    Poole, Dorset
    +58
    You can register your details online at www.panasonic.co.uk
    That is how I registered my plasma.
    HTH
  6. jasper1
    jasper1
    May 23, 2005
    75
    Nr Oswestry
    +12
    I just registered mine on the panasonic website, filled in model, address details, serial number, date purchased etc and then at the end after the final page (I'd put that I only had the standard one year guarantee) they offered me a choice of extended warranties, which I did not take up.
