Pv500 Wal
Discussion in 'Plasma TVs' started by DWF, Jun 12, 2005.
  1. DWF
    DWF
    May 22, 2005
    74
    11
    Does anyone know where i could get a wall bracket for my PV500, i got it with the CAB, but want to wall hang it now, or if it will take any uni wall stand?
    thanks
  2. greyhorse
    greyhorse
    Apr 16, 2005
    445
    do you want to sell the cab ???
  3. banditash
    banditash
    Dec 24, 2001
    38
    Lancs
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,059
    2
    4
    137
    Garstang, Lancs
    +1,597
    The universal one I got with my PV500 from RGB is good, sits it flush to the wall.
  5. DWF
    DWF
    May 22, 2005
    74
    11
    whats yours called Mal?
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,059
    2
    4
    137
    Garstang, Lancs
    +1,597
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    that looks very very similar to the RS100 £99 mount! cant see from the RGB picture but drop RS100 a call or AV-sales do a tilt universal mount that should fit give them a call too
  8. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,059
    2
    4
    137
    Garstang, Lancs
    +1,597
    It is expensive but I got it with the plasma, the cheaper ones will do the same job, they are all basically mild steel pressed out to give the shape.
    Should be getting my HK DVD player today :thumbsup:
  9. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,059
    2
    4
    137
    Garstang, Lancs
    +1,597
    You just need spacers for the vieras, about 45mm to stand it off the bracket (for the fat bit at the bottom)
  10. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    My 37PV500 arrives on Wednesday, and will be leaned against the wall until we decide where it should go! I'm now thinking that an articulated (swing) wall mount with 2 hinges would be best, so that we can swing it out from the recess beside the chimney breast and angle it in towards the room. As the PV500s are heavy buggers, can anyone recommend an articulated mount (it will be bolted onto a solid stone wall)?
    I saw some at the Bristol Show that looked very well made, but I can't remember who made them. I'd love an electric one, but those seem to cost about a grand!
  11. banditash
    banditash
    Dec 24, 2001
    38
    Lancs
  12. blzbob
    blzbob
    Oct 6, 2002
    43
    Newbury
    I got a universal wall mount with my PV500 (as panny had run out of stock) but I can't see where to attach it.
    There are 4 plastic caps at the back, do I prise these out and secure it here with the spacers? The other screws I can see don't look like they could bear any weight.
  13. Andy130
    Andy130
    Mar 17, 2005
    777
    28
    St Helens
    +38
    sorry to hijack the thread.
    But I have mine in the classifieds for £290 if your interested
  14. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,059
    2
    4
    137
    Garstang, Lancs
    +1,597
    You prise the caps off, and secure with the allen screw and the spacers.
    It doesn't look like it would hold the plasma but it does.
