PV500 Sound
Discussion in 'Plasma TVs Forum' started by danfbaxter, Jun 6, 2005.
  1. danfbaxter
    danfbaxter
    Jun 6, 2005
    5
    Help wanted! I set my new PV500 last week and while Im loving it I wonder if I have a problem, my Set gives off a high pitched low frequency whistling noise which while isnt ear splitting it is still very annoying, is this a fault, problem that can be solved or just what happens?
    Cheers,
    Dan
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    It is a fault with the sound amp, you shuld get it sorted
  3. dram
    dram
    I have a similar problem but thought it was more related to the cooling mechanism / inductor / capacitor hum. The humming seems to vary with what is displayed, e.g. EPG or dark screen.
    Bloody annoying late at night when the telly is on low volume.
