PV500 Sound?
Discussion in 'Plasma TVs' started by alliwant, May 30, 2005.
  1. alliwant
    alliwant
    Does anyone know if you can use the speakers in the pv500 as a centre channel speaker? any info would be apprecaited. :smashin:
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    i dont own one but i believe there are L+R rca inputs on the back which can be tied to any video input? (or maybe theres one for each input?) and you can then get a y splitter (designed for subs which make one channel into two see here http://www.tvcables.co.uk/cgi-bin/tvcables/XFA08-Y1F.html) and use the centre pre-out on your av reciever and connect it to these inputs.
    apparantely the sound is fantastic! good luck
  3. alliwant
    alliwant
    Cheers Chedmaster. Can someone who owns one check to see if this is true and will work? Does any one think i will lose out on that all important cinematic experience by doing this? Looking to team this with gallo diva's and micros,
