PV500 service menu
Discussion in 'Plasma TVs Forum' started by Thatsnotmynaim, Jul 2, 2005.
  1. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    3,662
    137
    Middle Earth
    +595
    Anyone know how to get into here? I want to adjust the H+V size to get 1:1 pixel mapping with my iScan. The vertical looks fine, but the horizontal is out.
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
  3. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    3,662
    137
    Middle Earth
    +595
    Thanks Mal
    I can get in and cycle through the menu, looks scary! I have a problem though as once I cycle through to the end, pressing the hold button does nothing so I'm stuck and can't get into service 2.
  4. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    3,662
    137
    Middle Earth
    +595
    The menu I get to when it will go no further is :-
    Service 1
    SD Auto Check
    Access
    if that helps anyone.
  5. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    3,662
    137
    Middle Earth
    +595
    Ooh, I'm into Service 2 now, not sure why that wouldn't work before. Anyway, I can't actually see anything that looks like it may adjust the H-size like I had on my PW6. :(
  6. Korum
    Korum
    Feb 19, 2005
    4,352
    Stockton-on-Tees
    +701
    can anyone explain the options in service menu 2 and how you adjust them.I need to adjust the horizontal positioning and i have no idea how to do it.surely it should be easy to adjust something as simple as this without having to trawl through service menus.
