Pv500 SD Card Recording Question
Discussion in 'Plasma TVs Forum' started by srgalpin, Aug 30, 2005.
  1. srgalpin
    srgalpin
    Hi All,
    I am looking to buy 37PV500 and have read all the threads reviews etc and am fairly settled on it. There is one question that I cannot find answered anywhere and that is how much record time is there on either a 1GB or 2GB SD card?
    I have read that you can record in MPEG4 onto the SDCard but this doesn't tell you how long you get. Does anyone know how much time you can get on a 1GB or 2GB card?
    Would be very grateful for any info!!
    Many Thanks
    Scott
  2. greyhorse
    greyhorse
    Apr 16, 2005
    447
    you can get around 2hrs on the 2gb card although the quality isnt great.
  3. gibreal
    gibreal
    Apr 10, 2005
    26
    havent used this yet on mine -no SD card.
    None of the reviews seemed to talk about it? Im gathering its not great but would like to hear other opinions?
    does any body use it?
  4. salfordred
    salfordred
    Feb 2, 2005
    89
    I'm likely to use it for viewing photos.... I'm guessing it does that.
