PV500 Running Time
Discussion in 'Plasma TVs Forum' started by Big-skaz, Jun 14, 2005.
  1. Big-skaz
    Big-skaz
    Hi Everybody. I had my new PV500 delivered on saturday and have just checked the hours running time in the service menu and it is showing 102! I know that that we have only had the screen on for about 15-20 hours max. Surely a new screen would not have 70 hours running time already. Spoke to the retailer today anyway because I had noticed marks on the top of screen surround and he advised that I should remove protective film but I have checked and cannot see any film attached!
  2. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    48
    +121
    looks like a return/ demo unit. Tell them to come and collect it with a brand new replacement!
  3. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +141
    Over 70 hours seems excessive to me. I'm not sure if the PV500 is the same as the PE30 but the protective film over the glossy black glass can be hard to find. Check out the following thread from last year:
    http://www.avforums.com/forums/showthread.php?t=176239
    S.
  4. Big-skaz
    Big-skaz
    Thanks for the info. Still cannot see any plastic film. If I admit to using the service menu to check hours used will this have any affect on warranty do you know? Thanks for the info again.
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    Not sure on this but I doubt it. If you have not made any adjustments in the service menu or actuall opened up the back of the plasma and had a poke around , then you should be ok. You may however have a problem actualyl proving that you did not clock up the hours yourself. I suppose it really does depend on where you bought it from and what thier customer service is like.
    Let us know how you get on.
    Note. If it is a brand new set then it really should have a thin polytheen cover on the glossy black surround. IF you can not possible find it then that may go towards proving that it is not a new set.
    Dave.
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Did you get the option to put in you name and postcode, if not, then it is probably not brand new
  7. greyhorse
    greyhorse
    Apr 16, 2005
    447
    did a check on mine and I have had it 10 days, only clocked up 50 hrs, I would send it back this screen has been on demo !!!
  8. j633295
    j633295
    May 2, 2005
    Please can someone tell me how to access the service menu to see the running time? :confused:
  9. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    here you go
    Originally Posted by Dave-S
    Here is how it is got into.
    turn to channel 99
    bass to max.
    treble to min.
    then press v/- 0n front panel at the same time as index on remote.
    this is service one.
    press the green button on the remote to cycle through the options untill you can go no further I think it stops at jpeg viewer options.
    then press hold on remote.
    service two should now be showing.
    press the green button and cycle through the options untill you get to the option that says hours used or some thing like that, not sure of exact wording. the value displayed is how many hours it has been on.
    words of advise
    do not change or alter any thing in these menus unless you are absolutly sure of what you are doing.
    You can do some serious damage to your plasma if you are not carefull.
    to get out of the service menu press exit on remote. if that does not work turn the plasma off ten back on again and you should be out of it.
    I take no responsability for any problems caused by entering the service menu
  10. Big-skaz
    Big-skaz
    Have spoke to the retailers today and they have agreed to exchange for new screen. Did not mention about the number of hours run just about the marks again. Come to think of it I did not get the prompt come up about owner id and address so was probably old demo stock! Thanks for your help.
  11. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Sounds like you sussed them out :thumbsup:
  12. Rapid 17
    Rapid 17
    Jan 14, 2005
    892
    28
    +78
    Big-Skaz, which dealer did you buy your pv500 from ?
  13. j633295
    j633295
    May 2, 2005
    Thanks for your help Dave-S,
    I followed the instructions however when I got to....
    It wouldn't go beyond service 1 and hence I couldn't get to see the running time. I wonder whether it is different for the PV500?
    Does anyone have any luck? :lease:
  14. Big-skaz
    Big-skaz
    Bought it from Crampton & Moore - they had it in stock. Have been good about sending replacement.
  15. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    Are you scrolling through to the jpeg viewer first, and then pressing hold?
    If you are just entering service one and pressing hold without being on the jpeg viewer option, it will not work.
  16. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    You have to scroll right to the end, it isn't JPEG viewer on the PV500, it is something else, just keep scolling until is stops, it is SD update or something.
  17. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    I've gotten to service menu 1, and the last option is Service 1 - SD Auto Check Access. Pressing hold does not bring up service 2?
    Edit - it does work, it changed to channel 91 while I was trying to get it to work.
    Mine has been used for nine hours since I got it yesterday :D
  18. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    Ah, that would explain it then. I was under the impresion that it was the same for the pv500 as for the pe30. Thanks for the info :)
