PV500 Remote not responsive?
Discussion in 'Plasma TVs Forum' started by CopperCircle, Jul 31, 2005.
  1. CopperCircle
    CopperCircle
    Hi, I have just got my TH-37PV500B and im very happy with it, apart from the remote which only seems to work when I point it directly at the sensor on the front of the set. I have tried different batteries but it's the same.
    Does anyone else have this problem?
    Thanks.
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Not had this problem with my Viera pe30, but make sure that the batteries are in nice and tight. Also I belive the remote has a switch which will make it control a dvd player or VCR. make sure the remote is switched to the TV position. Other than that most remotes do have to be pointing in the direction that the TV/DVD player is to work although they will normally work if pointed at an angle to the device that you are trying to work.
    Dave.
  3. TonyA
    TonyA
    Oct 16, 2004
    2,765
    London
    +217
    Hi - I noticed this too. You only have to point it slightly away from the set for the remote not to work.
    Its down to the remote Infra-Red transmitter imho, as I've tried it with the Harmony 885 (programmable Remote), and it makes the tv work even when pointing at the ceiling (don't ask!).
  4. Kaminsky
    Kaminsky
    Apr 26, 2005
    23
    Yep, me too..no big deal.
