PV500 recording on Sony PSP?
Discussion in 'Plasma TVs' started by Wall, Sep 7, 2005.
  1. Wall
    Wall
    Has anyone tried recording TV onto a Sony PSP formatted MemoryStick DUO using a PC-card adaptor? Awesome if this works!
  2. bishman
    bishman
    Mar 29, 2001
    4,902
    83
    hertford
    +172
    What format does the tv record in, I don't think the PSP will be able to play them without conversion? The PSP plays it's own mp4 format by defaullt, the files need a certain naming convention for the psp to recognise them. You can get AVI players to play avi on the PSP or you can use a utility such as pspvideo9 to convert to psp format. The avi players are in the early stages though and you will need version 1.5 firmware or earlier just now.
