PV500 Question
Discussion in 'Plasma TVs Forum' started by woodss, Jun 6, 2005.
  1. woodss
    woodss
    Sorry if this is the wrong forum, but...
    The SD Reader on the PV500 is a great idea. However, does anyone know if you can get a converter so that I can use my Sony memory sticks in it?
    Any suggestions would be most welcome.
  2. ajbird
    ajbird
    Apr 30, 2002
    105
    16
    Laceby - NE Lincs
    i thought sony only did sd cards? what type of memory card do you have? there is a pcmcia slot on the tv but the guy in the shop was a bit fuzzy on wether it could be used to read other memory cards.
  3. woodss
    woodss
    I was under the impression that the pv500 had a specific slot for SD cards as well as a PCMCI slot, perhaps one of the lucky owners could clarify.
    I currently have sony memory sticks for my camera etc - I why can't all manufacturers pick a format and stick with it :(
  4. ajbird
    ajbird
    Apr 30, 2002
    105
    16
    Laceby - NE Lincs
    yes it has both but no one has yet clarified if the pcmcia slot can be used to hold a converter card for dif flash types eg cf / smartmedia / multiedia / or if it is just for access cards
    sony normally use SD which is the same as what is on the pv500
  5. woodss
    woodss
    Cheers - has anyone used the SD slot on their PV500? I was just wondering how functional it was. For example can you just diplay pictures or will it play Mpeg files that are stored on the SD Card.
  6. smultron
    smultron
    Mar 6, 2003
    60
    Hamburg, Germany
    Sony normally uses "SONY", in this case memory sticks and not SD.
  7. leeboy22001
    leeboy22001
    Apr 18, 2005
    1,310
    63
    +128
    The PCMCIA slot is used for a PCMCIA card reader for all other memory cards :D i have used the SD card reader and its very easy to use, you get icons appear so selection of pics is dead easy :clap: you can also watch MPEG4 video. i've tried the SD card recorder, i.e. recorder say freeview onto the card, and its pretty poor, with bad lipsink on super fine res :( i'd only ever use it as a reader IMHO
  8. woodss
    woodss
    Does anyone know which is the best type of PC Card adapter to use with the PV500, in order to use Sony memory sticks?
  9. aliboy
    aliboy
  10. woodss
    woodss
    Cheers - I'll give that a go.
  11. Degs
    Degs
    Feb 4, 2002
    28
    +26
    SD recording is a bit of a gimmick but it's a great gimmick!!
    Recordings on the SD card play back superbly on a PDA using Betaplayer, for some reason I couldn't get any audio in Media Player.
    Dead easy to use too, had it recording through scart 1, put the TV into standby and it carried on recording.
    Can't beat a bit of Family Guy on the go :thumbsup:
  12. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I have the same problem in media player, is beta player free, have you got a link?
  13. woodss
    woodss
    Sorry to go off on a tangent, but I have another Question:
    Does anyone know the sky+ remote code to use the pv500 (and how to programme it).
  14. Sulis
    Sulis
    Mar 29, 2004
    577
    Bath
    ^^ I'd like to know, too - and does anyone know an app to view the SD card recordings on a Nokia Series 60 phone?
  15. Degs
    Degs
    Feb 4, 2002
    28
    +26
  16. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Got it thanks, they do look good on the PDA, probably because they are recorded at 320 x 240.
