PV500 - Possible to run a PC at 50hz?
Discussion in 'Plasma TVs Forum' started by MARSTC1, Mar 12, 2006.
  1. MARSTC1
    MARSTC1
    Aug 7, 2004
    30
    Does anyone know if it is possible to connect a PC to either the VGA port or the HDMI port on my Panny 42PV500 and run the signal at 50hz?
    I have a nVidia 6800 with VGA and DVI out. I am currently connected to the VGA port and I have run it at 1024 x 768 @ 60 and 75hz, but on both settings I suffer from the really anoying problem of frame judder / skip when using live TV on MCE.
  2. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Hi yes it is possible but I don't know how lol. I suffered from a little bit of judder and my son sorted it for me yesterday, I think he downloaded the latest version of mce tweak but will check with him later.
  3. MARSTC1
    MARSTC1
    Aug 7, 2004
    30
    Thanks Fossil, are you connected by vga or hdmi?
  4. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Connected via vga.
  5. MARSTC1
    MARSTC1
    Aug 7, 2004
    30
    That's good so am I:)
  6. MARSTC1
    MARSTC1
    Aug 7, 2004
    30
    fossil,
    Now your son has fixed the problem, if you watch sky sports news or bbc news would you say that the news ticker bar at the bottom of the screen is as smooth as the PV500's in built freeview tuner?
    Thanks for your help.
  7. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    75 Hz would have been fine if your gfx card/TV tuner software were properly de-interlacing the video which they don't seem to be doing (probably just bobbing the video fields for which you would need a 50 OR 100Hz refresh...so if 50Hz is not accepted by the display perhaps 100Hz will be...
  8. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Sorry can't help you there, not seen the PV500 at all. Still waiting for the son to come round but hopefully he will soon. Sorry couldn't have been more help.
  9. damo_in_sale
    damo_in_sale
    Jan 3, 2005
    2,877
    +565
    I don't think that's right mate, at least for video. Film maybe.
  10. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Its Vics son here. To enable 50hz for a nvidia card you need to go into geforce properties then screen resolutions & refresh rates once in there click on add in the custom resolutions bit and add 50hz in the last box, you wont need to alter any other settings. Once that has been done you will now need to tell mce not to overide the refresh rate. The easiest way is by following the following link http://www.avforums.com/forums/showthread.php?t=224652
    Hope this all helps.
    Steve
  11. MARSTC1
    MARSTC1
    Aug 7, 2004
    30
    Thanks Steve, I will give it a go :smashin:
  12. MARSTC1
    MARSTC1
    Aug 7, 2004
    30
    I have just added the custom resolution at 50hz but for some reason my panny is still saying that it's running at 60hz and the dreaded judder is still there :confused: I have checked that the reg hack and it works at 75hz. Any ideas what I'm doing wrong???
  13. Shimmyhill
    Shimmyhill
    Sep 24, 2005
    661
    Norwich
    +23
    My m8 has a PV500 and he says the VGA port can not take a 50hz signal at all. He checked with panasonic and i think it says it in the manual.
  14. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Sorry mate not sure. Is windows saying it is using 50hz. If it is Shimmyhills answer sounds right.
  15. Fossil
    Fossil
    May 29, 2005
    105
    +5
    As stated above it might be worth trying 100hz as a last resort.
  16. MARSTC1
    MARSTC1
    Aug 7, 2004
    30
    Unfortunately I get no signal on 100hz, I was wondering if anyone has had any joy in getting 50hz to work through the hdmi port???
