PV500 Pedestal question
Discussion in 'Plasma TVs' started by Ellispa, Aug 24, 2005.
  1. Ellispa
    Ellispa
    Aug 17, 2002
    182
    +13
    Hi All
    Can any of you owners with a PV500 and pedestal answer me this question.
    If you had it pushed as close to the wall as possible, how far from the wall would the front of the screen be?
    I am trying to work out how to position my projector screen so that I can pull it down in front of the plasma easily. I would consider wall mounting, but I have a new house with crappy walls that I have little confidence I can easily hang such a weighty device on, so pedestal and table top stand are the current favs. The Alphason stands with wall brackets seem like a good bet, but they appear to stick out too much for my liking.
    Cheers in advance and all.
  2. Branko
    Branko
    Aug 9, 2005
    23
    3
    The actual thickness of the plasma is around 5cm max but the pedestal does project beyond this.
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,078
    notts.
    +63
    Eight and a half inches from the back of the pedestal to the front of the screen. :)
  4. Ellispa
    Ellispa
    Aug 17, 2002
    182
    +13
    Thanks guys, just what I needed to know.
    Ta very much!
