PV500 - Panel only equivalent?
Discussion in 'Plasma TVs Forum' started by xprezz, Jul 20, 2005.
  1. xprezz
    xprezz
    Hey,
    I have read a lot about the Panny PV500 and it seems to be the best plasma buy at the moment, but I dont really like the wide bezel and speakers. Is there a panel only version of it, dont really need speakers or tuner, just boards for component, scart and vga and later HDMI.
  2. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    The new series 8 panels are out in September IIRC.
  3. xprezz
    xprezz
    Is there gonna be much of a difference between series 7 and the new 8?
  4. nheather
    nheather
    Oct 6, 2004
    17,433
    167
    Horsham, West Sussex
    +6,792
    PW8 coming in September/October
    It will probably work out more expensive than the PV500 because the boards have to be bought seperately.
    As an speculative indication reckon on
    Panel (includes VGA) - £2000
    SCART Terminal Board - £130
    Component Terminal Board - £130
    HDMI Terminal Board - £150
    Wall Bracket - £100
    TOTAL - £2500
    You may find that competative retailers bundle in a free terminal board
    Cheers,
    Nigel
  5. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    Doesn't PW8 have an SD res?
    I thought PHD8 would be the panel only version of the PV500?
  6. xprezz
    xprezz
    Hmm might just get the PV500 instead then and live with the wide bezel. Which panel is in the PV500 series 7 or 8, and if 7 does the coming series 8 mean that the PV500 is about to get replaced already?
  7. nheather
    nheather
    Oct 6, 2004
    17,433
    167
    +6,792
    No the PV500 is a series 8 panel - the TV version has been released ahead of the plain panel.
    Well spotted. Its what I was thinking of but I got the letters wrong. The rest of my post does apply to the PHD8
    Cheers,
    Nigel
  8. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    The change from 7 to 8 is quite considerable, the specs and brochures are ou there, there's a link in a recent thread, try a search. Some new stuff, and 50Hz compatibility improved.
